Rostislav_Zatol
16 years agoURL rewrite in HTTP body
Hello,
I have some dumb server application which is working with frames and onload java script.
Beside this we are using SSL offload on LB, so for many pages I have URL that is pointing to nowhere.
Client issues
GET https://server.domain/x
and gets following HTML body:
Is there any possibility to rewrite URL to https://server.domain/xyz in HTML body?
BR
RZ
- hoolio
Hi RZ,
You can use a stream profile and STREAM::expression iRule to rewrite response content. There are a few examples and details on the STREAM::expression wiki page (Click here).
The STREAM::expression value would be:
STREAM::expression "@http://server\.domain:80@https://server.domain@"
If you have questions or try something and it doesn't work, can you reply with the iRule and logs showing the issue?
Aaron
