Albert__Tase_70's avatar
Albert__Tase_70
Mar 14, 2008
url load balanceing and persistance
I need some help I need to match a https url if it matches I need to use ssl persistence and a different vip.
currently have a vip x.x.x.x listening on 443 if a request matches a sepfic url want to redirect it to a vip listening on 8443 else just want it to use the pool currently assigned to teh vip using 443. So should I use the when ssl_handshake ?
thanks
  • Take a look a the following links
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=2&postid=20266&view=topic
    http://devcentral.f5.com/Default.aspx?tabid=53&forumid=16&postid=18323&view=topic
    Try, as you said, using the event "when SERVERSSL_HANDSHAKE" However, I am not sure if this will work if the F5 is not carrying the cert. In that case you could probably use "when CLIENT_ACCEPTED"
    I hope this helps
    thanks,
    CB
