Sean_O_Brien_65
Feb 09, 2010url forward for http and https based on request
need an irule to forward to different url based on how the request came in...
example:
if {[HTTP::host] equals "dev.domain1.com"}{
HTTP::redirect "http://dev-domain1.domain2.com"
I need to add to this another domain url that looks the same but is 'qa' instead of 'dev'.
also would like this single iRule to handle http -> https at the same time, if possible... It sure seems like that shouldn't be an issue.
I tried doing this with an if / else, but I guess I'm having issue getting the syntax correct, but it seems like that would work.
Given our dns, only these two url's would ever go to this VS address.
Thanks!
- hoolio
Hi Sean,
Here is an example:when HTTP_REQUEST { Check the requested host header (set to lowercase) switch [string tolower [HTTP::host]] { "dev.domain1.com" { HTTP::redirect "http://dev-domain1.domain2.com" } "qa.domain1.com" { HTTP::redirect "http://qa-domain1.domain2.com" } default { Take some default action? Requests using the IP address would hit here } } }
Aaron - Sean_O_Brien_65
Awesome, thanks for the help!
I'm trying this now... just waiting for my DNS to update. - hoolio
You could test this by adding host file entries on your client (/etc/hosts for *nix or c:\windows\system32\drivers\etc\hosts on Windows).
Posted By hoolio on 02/10/2010 8:32 AM
Aaron
Yes, understood. I'm remoted in via VPN and I have other folks looking at this as well so I did test locally, but wanted others to use the updated DNS.
Also, I just got it working, just wanted to let you know (and others if following) that I had an issue, but realized I had an old wildcard cert loaded on the https VS so I was getting prompted before the redirect when trying https:// but the http:// worked so I knew it was a different issue.
Thanks again for the help. I love these iRules but I can never seem to get them first try!
