Drew_24540's avatar
Drew_24540
Aug 04, 2009
uri redirect help please
I am trying to use the following Irule to redirect to a URI...but it is not working. any thoughts?
if {[HTTP::uri] equals {http://start/}} {HTTP::uri {http://start.beazer.com/citrix/xenapp/auth/login.aspx}
  • hoolio's avatar
    hoolio
    Take a quick look at the descriptions for HTTP::host (Click here) and HTTP::uri (Click here) and then give this a try:
         Check requested host
        if {[string tolower [HTTP::host]]" eq "start"}{
            Check requested URI
           if {[HTTP::uri] eq "/"}{
               Redirect client to new location
              HTTP::redirect "http://start.beazer.com/citrix/xenapp/auth/login.aspx"
    Aaron
  • AWESOME! That did exactly what I needed Hoolio! Thanks for your assist!
    Edit---is it possible to wildcard after the start...say if someone typed in "http://start.beazer.com or http://start.beazer.net?
