eirikn's avatar
eirikn
Feb 16, 2016
URI pool selection using Data Groups (iRule)
Im trying to use a data group for pool selection with certain URI's, but I cant get it to work.
This is my Data Group (only one entry atm)
ltm data-group internal /DMZ/dg_dmz_foobar.customer.com_app {
records {
    /test-uri-web {
        data pool_web_pool
type string
This is my iRule:
  log local0. "DMZ test request: [HTTP::uri] IP: [IP::remote_addr] port [TCP::local_port]"
set app_pool_destination [class match -value [string tolower [HTTP::uri]] starts_with dg_dmz_foobar.customer.com_app ]
if { $app_pool_destination ne ""} {
pool $app_pool_destination
nexthop 172.21.179.1
Expected result: User is browsing a host with a URI that starts with "/test-uri-web" The correct pool is selected acording to the data group value of that URI. There will be alot of these entry's, hence the datagroup.
Any help is appreciated!
  • mo_99289's avatar
    mo_99289
    Historic F5 Account
    didn't see any errors in your irule. if it didn't work, what unexpected result did you get?
  • eirikn's avatar
    eirikn
    I actually got it working! I have some other stuff in the irule that was also hitting, and I forgot a "return" in the above if statement. Now with return the other part of the irule do not also hit :)
    Thanks for verifying my iRule though, helps to get some fresh eyes!
