Urgent -- Help with import_from_archive_stream() key/cert management API call
Hello,
I am trying to use the import_from_archive_stream() function as documented here:
https://devcentral.f5.com/wiki/iControl.Management__KeyCertificate__import_from_archive_stream.ashx
I have managed to get the archive stream over to the F5, and I can see that it indeed is untarred into a temporary directory /var/run/tempssl.
However, the certificate/keys are never fully imported. The API call does not return an error but it never installs the given key/cert. (I am only placing 1 key and 1 certificate in the tar stream.)
I suspect there is something wrong with the two arguments certs and keys that I am sending. At present, I am just placing the filename of the cert into the certs argument (in a sequence container of course). Likewise with the keys argument.
The documentation says only this:
certs = The string identifications of the keys to be imported/installed.
keys = The string identifications of the certificates to be imported/installed.
Can someone on the developer side please elaborate on how to properly use this API call? I have a major effort underway to replace all our 1024 bit keys/certs with 2048-bit and getting this to work right is crucial.
Thanks,
-M
- mhite_60883
Cirrocumulus
I'm pretty sure import_from_archive_stream() doesn't actually work.
