trungleon_11288's avatar
trungleon_11288
Mar 14, 2012
Unstable with Virtual Servers when running Active/Standby F5 Big-IP LTM 3600 ver 11.1
Hi all,
Our system have two F5 Big-IP LTM 3600 running under TMOS ver 11.1 with Active/Standby Mode. They have information as followings:
1. F5_01:
VLAN DMZ (Internal) Self IP: 10.5.255.252/16
VLAN DMZ (Internal) Floating IP: 10.5.255.254/16
VLAN LTM (External) Self IP: 10.6.255.252/16
VLAN LTM (External) Floating IP: 10.6.255.254/16
2. F5_02:
VLAN DMZ (Internal) Self IP: 10.5.255.253/16
VLAN LTM (External) Self IP: 10.6.255.253/16
In additional, we have the the Virtual Servers: 10.6.1.10/16 attaches to the Pool that is included 06 web members port 8080 (10.5.1.61/16 -> 10.5.1.67/16). Of course, the Gateway for each web member is 10.5.255.254/16 (Floating IP for VLAN DMZ).
But now, when the Client access to the Virtual Servers: 10.6.1.10, it's very unstable (sometimes run and sometime can't).
The following process:
1. Accessable with 10.6.1.10 -> this mean can ping 10.6.1.10 from outside.
2. Inaccessable with 10.6.1.10 -> this mean can't ping 10.6.1.10 from outside.
So we need from your support to solve this issues.
Best Regards,
Trungleon
  • As Techgeeeg suggested, I think opening a case with F5 Support will be the best way to get comprehensive help to troubleshoot the issues.
    Aaron
