Unstable F5 device with it's Peer
Hi
I have two F5 BigIp4000 running in cluster mode as Active/Standby mode. i noticed that the active device is showing disconnect and connect behaviour with it's peer. the LTM logs are : from the Active node: CMI reconnect timer: enabled Attempting to connect to CMI peer 192.168.255.254 port 6699 CMI peer connection established to 192.168.255.254 port 6699 CMI reconnect timer: disabled, all peers are connected Connection to CMI peer 192.168.255.254 has been removed CMI reconnect timer: enabled Attempting to connect to CMI peer 192.168.255.254 port 6699 CMI peer connection established to 192.168.255.254 port 6699 CMI reconnect timer: disabled, all peers are connected Connection to CMI peer 192.168.255.254 has been removed
from the standby node:
Aggressive mode sweeper: 1 Connections killed Aggressive mode sweeper: 3 Connections killed Aggressive mode sweeper: 1 Connections killed
the automatic sync is enabled,
please i need your help to solve this issue.
thank you.
if this is a critical system and you have support i would advise you to contact F5 support and open a ticket.
if you want to trouble shoot via this place then i would first go to through the trouble shooting SOL about sync issue. it seems that for some reason your systems don't communicate any more.
http://support.f5.com/kb/en-us/solutions/public/13000/900/sol13946.html
the aggressive mode sweeper might indication heavy load / many sessions on the standby node.
