dimka___104021's avatar
dimka___104021
May 21, 2008
universal persistence is not persistent?
I'm using custom universal persistency, which is assigned to VS. If in request specific string found in URL, it persists this request.
But strange thing is happens in persistency table. Why "b persist all show all" shows for same VS and same "Value" different nodes?
Mode: universal Value: -1398177477
Virtual: 192.168.80.205:https Node: 172.28.252.42:9300 Age: 0sec
Virtual: 192.168.80.205:https Node: 172.28.252.165:9081 Age: 0sec
Virtual: 192.168.80.205:https Node: 172.28.252.166:9303 Age: 0sec
This weird thing have been noticed on 9.4.3 & 9.1.3.
  • hoolio's avatar
    hoolio
    Do you see duplicate persistence entries for all requests? Can you post the iRule which you're testing?
    Aaron
  • here you go:
    pers_vs12 persistency profile assigned to VS
    profile persist pers_vs12 {
    defaults from universal
    mode universal
    mirror enable
    timeout 3600
    rule pers_vs12
    rule pers_vs12 {
    when HTTP_RESPONSE {
    if { [HTTP::header exists "jsessionid"] } {
    set jsess_resp [findstr [HTTP::header "jsessionid"] "!" 1 "!"]
    if { $jsess_resp != "" } {
    persist add uie $jsess_resp
    This is irule i use for persistency:
    if { [HTTP::uri] starts_with "/app12" } {
    set jsess [findstr [HTTP::uri] "!" 1 "?"]
    if { $jsess != "" } {
    HTTP::header insert X-WebLogic-Force-JVMID $jsess
    persist universal $jsess
    pool app12_dyn_be
  • Duplicates are for some requests:
    Mode: universal Value: 1835648582
    Virtual: 192.168.80.205:webcache Node: 172.28.252.150:9080 Age: 349sec
    Virtual: 192.168.80.205:webcache Node: 172.28.252.156:9201 Age: 216sec
    If i persist by URL string part (1835648582 in this case), which node is used and why?
  • hoolio's avatar
    hoolio
    So you see multiple persistence records for the same value intermittently (not on every request)?
    I'm not sure what would cause this. Here's a stab in the dark...
    If you change the pers_vs12 rule's line from
    to
    persist add uie $jsess_resp 3600
    and then remove the universal persistence profile from the VIP, do you still see the issue occur?
    Aaron
