Understanding tcpdump output
Hi all, I'm trying to understand the tcpdump output and after reading a few guidelines, may I just query a few items I don't understand.
1) From other links, their tcpdump would display the timestamp but it seems from mine I'm getting the counting of seconds from the time I start the tcpdump. How do I get the F5 timestamp as I will need it for investigation purpose ?
2) On line 4, the Seq value changes to "1" does it means data is being push from the source to destination ?
3) On line 5, the Ack value display as "187" does it means it's different connection from the previous one ?
4) On line 14, the FIN would means a graceful closure of the connection, would I be able to tell which connection is being close ?
Source: 10.0.0.1
Dest: 10.0.0.2
Seq Time Source Destination Protocol Length Info
2 25.895186 10.0.0.1 10.0.0.2 TCP 58 19032 > 10084 [SYN] Seq=0 Win=2048 Len=0 MSS=1460
3 25.895247 10.0.0.2 10.0.0.1 TCP 58 10084 > 19032 [SYN, ACK] Seq=0 Ack=1 Win=4380 Len=0 MSS=1460
4 26.019773 10.0.0.1 10.0.0.2 TCP 240 19032 > 10084 [PSH, ACK] Seq=1 Ack=1 Win=2048 Len=186
5 26.019818 10.0.0.2 10.0.0.1 TCP 54 10084 > 19032 [ACK] Seq=1 Ack=187 Win=4566 Len=0
6 26.495622 10.0.0.2 10.0.0.1 TCP 316 10084 > 19032 [PSH, ACK] Seq=1 Ack=187 Win=4566 Len=262
7 26.634369 10.0.0.1 10.0.0.2 TCP 54 19032 > 10084 [PSH, ACK] Seq=187 Ack=263 Win=2048 Len=0
8 38.894968 10.0.0.1 10.0.0.2 TCP 58 11323 > 10084 [SYN] Seq=0 Win=2048 Len=0 MSS=1460
9 38.894986 10.0.0.2 10.0.0.1 TCP 58 10084 > 11323 [SYN, ACK] Seq=0 Ack=1 Win=4380 Len=0 MSS=1460
10 39.019084 10.0.0.1 10.0.0.2 TCP 237 11323 > 10084 [PSH, ACK] Seq=1 Ack=1 Win=2048 Len=183
11 39.019129 10.0.0.2 10.0.0.1 TCP 54 10084 > 11323 [ACK] Seq=1 Ack=184 Win=4563 Len=0
12 39.481991 10.0.0.2 10.0.0.1 TCP 314 10084 > 11323 [PSH, ACK] Seq=1 Ack=184 Win=4563 Len=260
13 39.621209 10.0.0.1 10.0.0.2 TCP 54 11323 > 10084 [PSH, ACK] Seq=184 Ack=261 Win=2048 Len=0
14 49.002323 10.0.0.1 10.0.0.2 TCP 54 18192 > 10084 [FIN, PSH, ACK] Seq=1 Ack=1 Win=2048 Len=0
15 49.002341 10.0.0.2 10.0.0.1 TCP 54 10084 > 18192 [ACK] Seq=1 Ack=2 Win=4566 Len=0
16 49.003114 10.0.0.2 10.0.0.1 TCP 54 10084 > 18192 [FIN, ACK] Seq=1 Ack=2 Win=4566 Len=0
17 49.098877 10.0.0.1 10.0.0.2 TCP 54 18192 > 10084 [PSH, ACK] Seq=2 Ack=2 Win=2048 Len=0
- nitass
Employee
are you using wireshark? if yes, there is time display format under view menu.
sequence number is 1 because it is the first packet containing payload.
187 is acknowledgement of packet 4.
Understanding TCP Sequence and Acknowledgment Numbers by stretch
http://packetlife.net/blog/2010/jun/7/understanding-tcp-sequence-acknowledgment-numbers/4) On line 14, the FIN would means a graceful closure of the connection, would I be able to tell which connection is being close ?
i do not see 3 way handshake of that connection (between port 18192 and port 10084).
