kamlyada_209668's avatar
kamlyada_209668
Apr 27, 2017
Unable to access url ( first 2 attempts successful and 3,4,5 not successful
Hello,
I am accessing Below are the response I am getting... if two response I am able to access but next third ,fourth and fifth try..i am not able to acess.. This happens in successive pattern...if 2 are OK and 3,4 and 5 try are not OK. Could you please tell me possible reason ..what setting changes needs to be done on f5. I checked no issue observed on server ..Please help
Regards Kamlesh y
  • Did you check the F5 logs? I guess, Server port is bouncing. Packet capture(TCPDUMP) is best option to troubleshoot further.
    • kamlyada_209668's avatar
      kamlyada_209668
      This is was the question asked in Interview.. What are the possible reason for this successive patterns...?
  • Hi,
    what is your configuration?
    do you use irule, http profile, ...?
    with the provided information, nobody can help you.
