Unable to access Management GUI using IE
I am unable to access my Active LTM using IE. It just tries for a long time and gives a time out. However, my Standby LTM works fine with the same browser.
Pls help..
- Arie
Altostratus
Are you having the same problem with other browsers? What about the iRule editor? Can you connect to both the active and inactive system?
- Torti
Cirrus
it depends on your IE version and your LTM version, look into release notes. But you should allways use the irule editor to change irules.
- Arun_6466
Hi Torti,
I am not trying to change the irules. All i need is access the GUI. Both the LTMs are running the same TMM version and i am able to access one and not able to access the other.
What could be the possible reason or how could i troubleshoot this issue ?
- Arie
Altostratus
Torti,
The iRule editor uses HTTPS to communicate with the BIG-IPs. It would therefore provide a good way to test connectivity to both BIG-IPs.
To get the root cause, I would check the status of httpd and tomcat service.
bigstart status httpd bigstart status tomcatrun "top" to see memory utilization/cpu by these process. check httpd log and catalina.log
To Resolve, Restarting httpd and tomcat service has fixed most of issues for me.
bigstart restart httpd bigstart restart tomcat
