Types of Algorithm and their best use.
What types of algorithms are available in F5 (LTM/GTM) and how we can conclude that which is best to use for different types of application like web, database, hybrid etc. ? Need all this information in details.
Hi gurmjaspreet,
for SSL/TLS connections you may take a look to Stephans cipher cheat sheet. It contains all supported ciphers suites...
https://devcentral.f5.com/questions/tmos-ssl-tls-cipher-cheat-sheet
The conclusion which cipher should be used in these days, is more or less dictated by Qualys SSL Labs (almost every penetration tester are using their recommendations for their reports). You can scan your website by the Qualys SSL Labs free of charge and see what they are complaining here...
https://www.ssllabs.com/ssltest/analyze.html?d=devcentral.f5.com
You may also check a posting of mine to see which ciper suites should be used to achive an "A" or even "A+" rating.
https://devcentral.f5.com/questions/howto-getting-an-awesome-qualys-ssl-labs-rating-48120
Cheers, Kai
