N_67263's avatar
N_67263
Mar 04, 2014
Trying to understand the model of an F5 box
Folks,
I want to confirm the model of an F5 box we have, this is the output I received when I hit a "bigpipe platform" command.
[root@big-ip:Active] / bigpipe platform PLATFORM INFORMATION -- | Type C36 | Chassis: serial bip******s | 200 Level part number: 200-0252-07 REV B | Switch board: serial PCA0103MW797 part PCA-0103-03 REV C | Host board: serial TC7FF27A0343 part MOB-0017-05 REV A | Annunciator board: serial 714CF063319 part OEM-0029-07 REV B | BIOS rev: Unavailable | base MAC: 00:01:D7:69:A1:40 +-> CPU 1 temp 53degC fan speed 6420rpm | | CHASSIS TEMPERATURE | (1) 50degC (101) 37degC | | CHASSIS FAN | (101) active (102) active (103) active (104) active (105) active | (106) active | | POWER SUPPLY | (101) active [root@big-ip:Active] /
I understand that this is a BigIP LTM 1500 and should have a 1G memory, please correct me if I am wrong. Also how do confirm the memory in the device?
Regards, Nik
  • Hi, some information about 1500 https://www.f5.com/pdf/products/big-ip-platforms-2007-ds.pdf
    • Vitaliy_Savrans's avatar
      Vitaliy_Savrans
      also command 'top' will show memory on device: top - 10:17:48 up 24 days, 21:58, 1 user, load average: 0.23, 0.16, 0.10 Tasks: 272 total, 1 running, 268 sleeping, 0 stopped, 3 zombie Cpu(s): 6.1%us, 2.8%sy, 0.8%ni, 90.1%id, 0.2%wa, 0.0%hi, 0.0%si, 0.0%st Mem: 4060804k total, 4030560k used, 30244k free, 5632k buffers
  • nathe's avatar
    nathe
    "b memory show" is the bigpipe command to use
