Albert__Tase_70's avatar
Albert__Tase_70
Sep 07, 2007
trying to add the below to exsiting irule and keep getting errors please help
} elseif { ($uri starts_with "/dynasearch") || ($uri starts_with "/Dynasearch") || ($uri starts_with "/DynaSearch") } {
HTTP::redirect "http://www.palgrave-journals.com/common/access/replaced.vm"
pool palgrave-foxtrot
} elseif .....
the part i get syntax errors on is adding the else statement above its being added in the middle of the rule show the start of the next elseif statement.
error message [deprecated usage, use else or elseif] [ ]
else if (http_uri starts_with "/dynasearch" or http_uri starts_with "/Dynasearch" or http_uri starts_with "/DynaSearch") {
redirect to "http://www.palgrave-journals.com/common/access/replaced.vm"
else {
use pool palgrave-foxtrot
this is in th emiddle of the 4 verserion irule need to get in the 9 version and it just won't let me
atase
09/07/2007 7:50 AM Edit Quote Reply Alert
so are yo usaying it can't be converted it would have to go into the end of the rule ? this rule is 91 lines long
thanks
Al
  • hoolio's avatar
    hoolio
    Hi Al,
    The else should be the last clause:
    } elseif {
        something
    } elseif {
        something
        default action
    Also, you can set the $uri variable to lower case and do just one comparison:
    elseif {[string tolower $uri] starts_with "/Dynasearch"}{
    Aaron
  • else if (http_uri starts_with "/dynasearch" or http_uri starts_with "/Dynasearch" or http_uri starts_with "/DynaSearch") {
    else {
  • so are yo usaying it can't be converted it would have to go into the end of the rule ? this rule is 91 lines long
    thanks
    Al
  • hoolio's avatar
    hoolio
    The structure for an if statement is normally:
    if {some condition}{
        do something
    } elseif {some other condition}{
        do something else
        do something else
        take some default action
    All statements after the first 'if' are optional. Logically, you wouldn't want to put an else anywhere in the middle of the rule, as it would match any case up til then and stop the rule from ever processing any of the subsequent elseif's.
    If you want to perform other tests after the checks you posted, you could change the else to an elseif.
    Also, are you running 9.0.3 or 9.3.0? 9.0.3 is a very old version with a lot of issues. You should consider upgrading to the latest maintenance release in the 9.3.x branch.
    Aaron
  • It is very difficult to try to diagnose problems when you only post a small subset of your iRule (especially when an error is dependent on the other parts of the iRule). If you could post the complete section of your if clause, we might be able to help you better.
    -Joe
