Simon_Beaudoin's avatar
Simon_Beaudoin
Oct 27, 2020
Trying to achieve a specific configuration with an Irule and SSL Proxy.
Here is what we are trying to acheive to replace a Microsoft IIS Server.
Many of our client servers are note supporting TLS 1.2, So we have this webserver that acts as a proxy for them.
The IIS Server is presenting a certificate based on a hostname, Then the url requested is parsed ont the IIS server and the original client certificate is presented to the EXTERNAL website and data is exchanged through the IIS Server.
For an exemple :
Client ask for : https://iisredirect.sdswebapp.com/URL=login.decisivapps.com/oauth/token that goes to the IIS server.
IIS Server "comfort" client with it's own certificate.
Request is receveived at https://login.decisivapps.com/oauth/token from the IIS server on behalf of the client.
Then the IIS server exchanges data between them until completion.
We cannot use nodes because all those site are external.
What we've tested so far was an iRule that "works" on redirection only, but not as a proxy.
Our dev team would like to replace this IIS server without having to use nodes,datagroup or so. Only with the /URL=??? method already hardcoded on hundreds of servers.
Is there any way to achieve this ?
Thank you
  • > We cannot use nodes because all those site are external.
    You can define nodes that are external to the networks on the LTM.
    It's certainly achievable, but not trivial.
    I'd suggest approaching F5 Professional Services to get this written.
    Otherwise, here is a high-level irule structure
    you need server-ssl profiles for all the target severs, with relevant settings and client-auth certificates
    They need to be named in a structured way so they can be correctly selected with the host name
    get the request URI (HTTP:uri)
    split it on "URL=", and keep the second result
    Prepend "https://" so you have a target URI for the server-side response
    Use URI::host to get the host name
    use DNS::resolve to get an IP address from the host name
    set the node using the IP address
    change the Host header in the request
    select the correct server-ssl profile based on the hostname
    allow the request to be made
    once you have a response, translate any embedded URLs as required
