pedinopa_170325's avatar
pedinopa_170325
Aug 07, 2018
trouble rewiting path
I need to rewrite the REQUEST path that is returned to the browser. I have an irule which reads the REQUEST path, splits it into a variable which has the path I want (I logged it to my logging server so I know it contains what I want. I am having trouble with getting the HTTP::path modified.
First use hsl::open to define where to send logs and save it as a variable HSL
when CLIENT_ACCEPTED { set hsl [HSL::open -proto UDP -pool graylog2-syslog-pool] }
create variable to hold modified path, split on ;jsessionid
set nojsession [getfield [HTTP::path] ";jsessionid=" 1]
 Check if the path contains a jsessionid
if {[HTTP::path] contains ";jsessionid"}{
      write to log verify that the if clause and the variable are correct
     HSL::send $hsl "webmod This is the $nojsession without sessionid"
      replace the path with the variable (modified path without jsessionid)
     HTTP::path $nojsession
  • when CLIENT_ACCEPTED {
  • A few issues with your iRule, you are looking at the HTTP::path for a Query parameter which will never exist. Lets say the request is
    https://some.host.com/this/is/the/path?jsessionid=thequerypart
    You would get the following returned from different iRule commands:
    • HTTP::host =
      some.host.com
    • HTTP::path =
      /this/is/the/path
    • HTTP::uri =
    • HTTP::query =
    Your iRule would never find locate the
    jsessionid
    query and is only updating the HTTP path not the query.
    The following iRule does the same but using
    HTTP::uri
    instead of
    HTTP::path
         Check if the URI contains a jsessionid
        if {[HTTP::uri] contains ";jsessionid="}{
             Create variable to hold modified URI, split on ;jsessionid
            set nojsession [getfield [HTTP::uri] ";jsessionid=" 1]
             Write to log verify that the if clause and the variable are correct
             Replace the URI with the variable (modified URI without jsessionid)
            HTTP::uri $nojsession
    Quick note about this iRule if the request contains any query parameters after the
    jsessionid
    then they will be lost as the
    getfield
    command only takes the first part of the URI.
    e.g. If the URI requested is
    /this/is/the/path?page=test;jsessionid=thequerypart;user=bob
    the updated request would be
    and the query parameter
    user=bob
    would be lost.
