omidrostami_1994's avatar
omidrostami_1994
Oct 01, 2024
Traffic Learning Section Stuck Loading After TMOS Upgrade to 17.1.1.2
Hello,
I recently upgraded my TMOS version from 16.1.4.3 to 17.1.1.2 on our F5 device. After the upgrade, I noticed an issue with the Traffic Learning section in the ASM (Application Security Manager) module.
When I navigate to Security ›› Application Security ›› Policy Building ›› Traffic Learning, the section appears to load indefinitely when I try to view illegal suggestions. It seems to be stuck in a loading state, and I can't access the learning suggestions as I could before the upgrade.
thanks
  • Hi omidrostami_1994,
    It looks like a Bug in the new version, I recommend you restart the ASM Process in the standby unit with the command
    bigstart restart asm
    If this doesn´t work it´s probably that you have to open a support case to receive a hotfix to solve this issue, is common to get a hotfix from support for features like the OWASP top 10 dashboard.
    Hope it works.
  • Might be worth checking 17.1.1.3 and the more recent 17.1.1.4 release notes as well to see if that issue has already been in addressed in those versions. I know in my lab which is on the 17.1.1.3 Build 0.12.5 ENG HF does not experience that issue yet that I have seen.
    Also you could take a look at your logs (ltm, messages, tmm, asm) and recreate the issue and see if anything notable shows up. Such tomcat, restjavad and or asm processes having issue or dropping a core file. A lot of times when I run into Web Gui issues, always seems to be tomcat or restjavad having issues and typically giving them more memory helps. But just depends on what the logs show.
    https://my.f5.com/manage/s/article/K63328426
