belias21_8982
Aug 10, 2009Traffic between VLANs
DISCLAIMER: Total F5 n00b (as in, never configured one from scratch...)
Here's the deal. Single BigIP LTM device has 3 VLANs (external, web, app).
I set up a forwarding VS (net 0.0.0.0/0.0.0.0, all protocols, forwarding IP, all VLANs). Devices on web and app VLAN have F5 as their gateway. Given this configuration, should I not be able to ping across VLANs to other devices? Also, I am unable to ping an F5 self-IP that is on a diffeent VLAN. I am wondering if it is a routing issue. It is my impression that setting up the forwarding VS enables the passage of ICMP traffic.
Can someone point me in the right direction?
Thanks in advance!
Brian
- The_Bhattman
Hi Brian,
At face value you appear to have the correct settings. Click here if you want to view the specific Solution Article from F5 that provides the detail for allowing ICMP.
However, what the F5 will not allow is pinging the floating IP and self address of the active unit(in your case you have one F5) from the other side of the VLAN. For example, you can't ping the floating and self addresses on external from Web or App and vice versa.
I hope this helps,
CB
