Matt_H_58911
Feb 16, 2009To "/" or not to "/"
Hey all,
I have a weird one. I have a quick iRule that looks for a string and depending on the string forwards my request to a pool
switch -glob [string tolower [HTTP::path]] {
"/keysadmin*" -
"/uninstall*" -
"/link*" {
pool App_pool
log local0. "HTTPS App Pool chosen."
default {
pool Web_Deck_pool
log local0. "HTTPS Web Deck Pool chosen."
log local0. "[HTTP::uri]"
For the above iRule if I go to:
https://www.domain.com/keyad/ I get the expected page
if I go to https://www.domain.com/keyad I am redirected to a 404. Can I have the above iRule add the / for me so it works?
- Matt_H_58911
ooops..
Just to clerify my links should be:
https://www.domain.com/keyadmin/ I get the expected page
if I go to https://www.domain.com/keyadmin I am redirected to a 404. Can I have the above iRule add the / for me so it works? - hoolio
You could try, but it's hard to guess from an iRule which requests are files which should be left alone and which are directories which should end in a forward slash.
Why isn't the application redirecting the client to the correct location? Or is the app trying to? If you use a browser plugin like HttpFox for FF or Fiddler for IE, what do you see in the request/response headers leading up to the 404?
Aaron - hoolio
Are you redirected to http://www.domain.com/keyadmin/ and then get a 404? If so, you can enable rewrite redirects on a custom HTTP profile and add that to your HTTPS VIP to fix this. Try searching on AskF5.com or in the forums here for "rewrite redirects" for details.
Aaron - Matt_H_58911
Yes I am redirected to http://www.domain.com/keysadmin/
I found out the backend servers are IIS. So this "/" can be added per the IIS config. I am worried the HTTP rewrite will affect the other hits. - hoolio
If you specify All or Matching for rewrite redirects, LTM won't modify the URI--it will rewrite the protocol from http to https in the Location header. So the IIS servers will send a redirect to http://www.domain.com/keysadmin/ and LTM will rewrite it to https://www.domain.com/keysadmin/.
You can get more information on this in SOL6912.
SOL6912: Configuring an HTTP profile to rewrite URLs so that redirects from an HTTP server specify the HTTPS protocol (Click here)
Hey guys.... Thanks! I have created an http profile and enabled the Redirect Rewrite to "Matching" and that did what I needed.
