Stéph_6000's avatar
Stéph_6000
Sep 11, 2018
tmsh test-monitor : external executable not found
I'm trying to use the "test-monitor" function in tmsh but every time I use it I get the same answer:
root@(lb07067)(cfg-sync In Sync)(Active)(/Common)(tmos) test-monitor http address 10.221.62.23 port 8180 can't run 'http' monitor manually: external executable not found (http)
Even on the basic http default monitor.
Any clue ? Thanks
