MrVrba_172294
Sep 30, 2014tmsh: "terminal is not fully functional"
I am getting the following warning when trying to run
list sys global-settings all-properties via a tool with a "dummy" term:
WARNING: terminal is not full functional
/var/tmp/tmsh/xxxxx/data (press RETURN)
My first question is are you are able to set the TERM environment variable via tmsh? If not, what can I do to avoid this warning? I don't get this warning on all commands, just some. Seems very weird. Any help is appreciated. Thanks.
- MrVrba_172294
EDIT: Seems to work fine without the `all-properties` directive and also works fine (even WITH the `all-properties) interactively.
