aj1's avatar
aj1
10 years ago
tmsh show /sys connection cs-client-addr x.x.x.x using iControl REST
Been going through the iControl REST reference and it appears appending
stats
to the GET request outputs the
tmsh show ...
of a pool, virtual etc. I've tried the same approach for
tmsh show /sys connections
, and it outputs the complete table, unformatted. Is there any way this can be formatted into a human-readable format, just like the JSON output of a
tmsh list ...
command.
I would also like to trim that down (Since this is going to be a high load system) using
cs-client-addr
(or maybe multiple parameters). I can do this using
get_active_connection_v2
in iControl SOAP. Is there a way to do the same in REST?
    "apiRawValues": {
        "apiAnonymous": "Sys::Connections\n10.0.0.3:37843  10.0.0.2:179  10.0.0.3:37843  10.0.0.2:179  tcp  5  (slot/tmm: 1/0)  none\n10.0.1.3:57092    10.0.1.2:179    10.0.1.3:57092    10.0.1.2:179    tcp  6  (slot/tmm: 1/3)  none\n10.0.2.5:37506  10.0.2.4:179  10.0.2.5:37506  10.0.2.4:179  tcp  9  (slot/tmm: 1/1)  none\n10.0.3.3:48427  10.0.3.2:179  10.0.3.3:48427  10.0.3.2:179  tcp  5  (slot/tmm: 1/0)  none\n10.0.4.5:56145    10.0.4.32:53      10.0.4.5:56145    10.0.4.32:53      udp  0  (slot/tmm: 1/0)  none\nTotal records returned: 6\n"
    "kind": "tm:sys:connection:connectionstats",
    "selfLink": "https://localhost/mgmt/tm/sys/connection/stats?ver=11.6.0"
Thanks in advance!
  • Try this:
    curl -sk -u 'admin:admin' -H "Content-Type: application/json" -X GET "https://x.x.x.x/mgmt/tm/sys/connection?options=ss-client-addr+192.168.6.100&ss-clint-port+33761" |perl -pe 's/\\n/,\n/g'
  • aj1's avatar
    aj1
    Thank you Kevin. That worked like a charm. What would be the best way to parse the response table in
    apiAnonymous
    to display the inside address for the outside address sent in the request (that is
    cs-server-addr
    ). In the below output, I'd like to get the inside IP
    172.25.52.251%4
    $ curl -sk -u "admin:admin" -H "Content-Type: application/json" -X GET "https://x.x.x.x/mgmt/tm/sys/connection?options=ss-client-addr+197.72.208.78" | perl -pe 's/\\n/,\n/g'
    {"kind":"tm:sys:connection:connectionstats","selfLink":"https://localhost/mgmt/tm/sys/connection?options=ss-client-addr+197.72.208.78&ver=11.6.0","apiRawValues":{"apiAnonymous":"Sys::Connections,
    172.25.52.251%4:41334  69.28.57.177%4:10086  197.72.208.78:1142  69.28.57.177:10086  tcp  499  (slot/tmm: 1/0)  none,
    172.25.52.251%4:60179  193.235.206.82%4:4070  197.72.208.78:1043  193.235.206.82:4070  tcp  47  (slot/tmm: 1/0)  none,
    Total records returned: 2,
  • Okay, so you're output should look like this, yes?
    If so, are you just looking for the first address?
  • aj1's avatar
    aj1
    Yes Kevin, that is what my o/p looks like. Just want it to be cleaner at this point, by extracting the first address and displaying only that. I'm using python and the
    requests
    lib for GET(ting) the data, and currently, I can see a fraction of the connection table for that outside ip (
    cs-server-addr
    ). Thanks.
    >>> import requests
    >>> print connTable['apiRawValues']['apiAnonymous']
    Sys::Connections
  • One option?
    import re
    for line in open("test.txt", "r"):
        if re.search(r'^[^a-zA-Z].*', line) is not None:
            ip = line.split(" ")
            print ip[0]
  • Haven't tried it, but
    import re
    for line in connTable['apiRawValues']['apiAnonymous']:
            print ip[0]
  • Okay, for the sake of testing I just rebuilt the whole thing:
    import re
    import subprocess
    p1 = subprocess.Popen([
            'curl',
            '-sk',
            '-u',
            'admin:admin',
            '-H','Content-Type: application/json',
            '-H','Accept: application/json',
            '-X','GET',
            'https://x.x.x.x/mgmt/tm/sys/connection'
    ],stdout=subprocess.PIPE)
    p2 = subprocess.Popen([
            'perl',
            '-pe',
            '\'s/\\n/,\n/g\''
    ],stdin=p1.stdout,stdout=subprocess.PIPE)
    result = str(p2.communicate()).split('\\n')
    for line in result:
            if re.search('^[0-9].*', line) is not None:
                    print ip[0]
  • aj1's avatar
    aj1
    Works now! Turns out I was missing
    connTable.split('\n')
    🙂 Thank you for the detailed example above, interesting way of approaching it using
    subprocess
  • aj1's avatar
    aj1
    Hi Kevin. Apologies, should have tested this first time around, but it appears specifying the
    ss-client-port+33761
    option doesn't trim down the table any further, and instead gives all connection table entries based of
    . I can see only one entry on the BIG-IP (expected), but multiple when the same options are specified in GET.
     show sys connection ss-client-addr 197.72.206.124 ss-client-port 1199
    Sys::Connections
    172.25.24.86%4:49327  68.67.176.52%4:443  197.72.206.124:1199  68.67.176.52:443  tcp  578  (slot/tmm: 1/1)  none
    Total records returned: 1
    $ curl -sk -u 'admin:admin' -H "Content-Type: application/json" -X GET "https://x.x.x.x/mgmt/tm/sys/connection?options=ss-client-addr+197.72.206.124&ss-client-port+1199"
      "selfLink": "https://localhost/mgmt/tm/sys/connection?options=ss-client-addr+198.82.208.128&ver=11.6.0",
      "apiRawValues": {
        "apiAnonymous": "Sys::Connections\n172.25.24.86%4:49435  54.243.90.245%4:443  197.72.206.124:1051  54.243.90.245:443  tcp  35  (slot/tmm: 1/1)  none\n172.25.24.86%4:49327  68.67.176.52%4:443  197.72.206.124:1199  68.67.176.52:443  tcp  582  (slot/tmm: 1/1)  none\n172.25.24.86%4:49412  17.143.160.159%4:5223  197.72.206.124:1028  17.143.160.159:5223  tcp  402  (slot/tmm: 1/1)  none\nTotal records returned: 3\n"
