TMSH: Load backup configuration without restart of services, drop of connections
we are using version 11.4 and would like to know if we can apply same behavior as with bigpipe in tmsh.
Imagine that we will make a big modification of setup (virtuals, pools, nodes, monitors, ...) and would like to have quick restore procedure. On version 10.x we simply made backup of /config/bigip.conf, perform changes and if something goes wrong we just replaced bigip.conf from backup and execute "b load" which just read the local file and revert changes back in memory.
Now in TMSH you have the only option "load /sys config" which will restart almost all services and also drop all connections...
Your ideas are more than welcome
Thank you
From version 11.3 onwards there is change in behavior (which I think you might be already aware). It may behave as expected when you try to load only the specific partition on which you made the changes by
tmsh load /sys config partitions { MyExamplePartition }
- What_Lies_Bene1
I didn't think
caused a service restart or connection drops. Does it do so in your experience?tmsh load sys config - cmeldaq_16882
yes, we made SSH connection on box behind BigIP which has been dropped during load of configuration.
Thank you
- kridsana
Cirrocumulus
I think reload config made service interrupt.
- Domai
Altostratus
Yes load sys config did cause the connections to drop. But when you are making changes or updating some thing lets say pools or VS anything you can use verify/merge and write to the conf file. This will load the changes to the running config in memory. Once satisfied save config. This is the best process in my experience.
- Domai
Altostratus
More info - The tmm deamon itself does not get affected by the reload. SO I am not sure why the traffic was getting disrupted. I had a chance to pose the same question to an F5 SME and he said may be some other deamon that effects the traffic was getting recycled. I am still trying to find out which one by doing multiple reboots and checking for uptimes on the deamons. I think that is the only way to nail this down.
- PK_Bhatia
tmsh load /sys config partitions { MyExamplePartition }- cmeldaq_16882
Thank you! First tests confirm this
- PK_Bhatia
