Ray_Allen_75591
Nov 07, 2014TMSH How to add a irule to a vip with existing irules
I found the script RemoveIruleFromMulttipleVS which works great to remove a irule fom vips that have the same irule in them . I am looking for a script that will add iruleX to multiple VIPs that have existing irules and will not remove the existing irules .
- R_Marc
That would be fairly easy to do with iControl rest. Something like (using perl):
!/usr/bin/perl use JSON qw( decode_json ); use Getopt::Std; %opts=(); getopts("b:rv:tl:",\%opts); sub Usage { print "Usage: $0 [-b ] [-l ] [-r] [-v virtual] [t]\n"; print "\t -b target a particular node (default targets the active member of each cluster) \n"; print "\t -l : separated rule list\n"; print "\t -r replace rather than add\n"; print "\t -v virtual to operate on, default is all\n"; print "\t -t Test run\n"; exit; } if ($opts{h} || (!keys %opts)) { Usage(); } print "F5 Admin password:"; system('/usr/bin/stty', '-echo'); Disable echoing my $pass = <>; system('/usr/bin/stty', 'echo'); chomp $pass; print "\n"; my $res = `curl -sk -u admin:$pass -H "Content-Type: application/json" -X GET https://$opts{b}/mgmt/tm/ltm/virtual`; $decoded = decode_json($res); foreach my $item ( @{$decoded->{'items'}}) { my $json = "{\"name\":\"$item->{'name'}\",\"rules\":[ "; if ($opts{v} ) { if ( ! ($item->{'name'} =~ /$opts{v}/) ) { next; } } if ( $opts{r} || !(exists($item->{'rules'}))) { foreach my $rule (split(/:/,$opts{l})) { $json .= "\"$rule\","; } chop $json; $json .= "] }"; } elsif (exists($item->{'rules'})) { foreach my $rule ( @{$item->{'rules'}} ) { $json .= "\"$rule\","; } foreach my $rule (split(/:/,$opts{l})) { $json .= "\"$rule\","; } chop $json; $json .= "] }"; } if ($opts{t}) { print "curl -sk -u admin:$pass -H \"Content-Type: application/json\" -X PATCH https://$opts{b}/mgmt/tm/ltm/virtual/$item->{'name'} -d '$json'\n"; } else { `curl -sk -u admin:$pass -H "Content-Type: application/json" -X PATCH https://$opts{b}/mgmt/tm/ltm/virtual/$item->{'name'} -d $json`; } }
