TMSH Help After Upgrading from 10.2 to 11.3
Hi All, we just upgraded one of our test devices from 10.2.2 to 11.3 + HF8 and I am having some trouble editing my tmsh scripts that I created on 10.2.
On 10.2 I was able to enter tmsh, then type 'cli script', and then 'edit Name.tcl> and the script would pop up in VI and everything was fine. When I repeat these steps in 11.3 I get a 'Syntax Error: incomplete command'. If I just type 'list' it lists all of the scripts in the Common partition, but I am beating my head against the wall trying to figure out how to edit them, please help me. I'm sure this is something very simple I am just missing....
Thanks in advance for your help. Brian
- Cory_50405
Noctilucent
From tmsh, you'll now need to 'run cli script'
- Brian_Kenworthy
Thanks Cory, I know how to run it, but I first need to edit it but I keep getting syntax errors. What is the command to edit a script?
- Brian_Kenworthy
It appears that in V11 in order to create/edit TMSH scripts you have to be in the Administrator role, Resource Administrators no longer have the ability to create/edit scripts. Can someone confirm that?
Also, is there a way to grant users in the Resource Administrator role the ability to create/edit TMSH scripts in a different partition other than /Common?
Thanks in advance.
