Mahmoud_Eldeeb_
Apr 14, 2014TMG Replacement
TMG is only working as a publisher, it publish many web-servers with a single IP Addresse. how do I do the same task into LTM 11.5.1??
- kunjan
APM portal will give this capability.
http://support.f5.com/kb/en-us/products/big-ip_apm/manuals/product/apm-portal-access-11-5-0/1.html
- Mahmoud_Eldeeb_
Does LTM do the job ??
- kunjan
Policies do the same thing as proxypass but without the iRule needed.
- Mahmoud_Eldeeb_
How do I do with the aid of policies ?? - For example, you'd need to create a policy with requires - http, controls - forwarding. Then you can setup rules. I have rules setup to watch http-host for certain conditions, and when that particular condition is met the traffic is forwarded on to the appropriate pool via the rule actions. You can have multiple rules per policy so you can have multiple URLs all hitting the same vip. Front end it with APM policy and this is how I replaced our TMG.
- Mahmoud_Eldeeb_
i have no APM, there are LTM & ASM only
- Mahmoud_Eldeeb_
I had only LTM & ASM, there is no APM.
