rajesh_74821's avatar
rajesh_74821
Nov 18, 2009
ThreadPooling implementation problem
Hi All,
In our BigIp box
1) For GlobalLB I am having min 500 wideips and 500 pools and 1000 poolmembers
2) through config file i am getting all the list of wideips, pools and poolMembers and store in to database.
3) For statistics :
while getting these statistics I am implementing thread pooling mechanism and assigning the list of wideips, pools and poolmebers to threads for getting the statistics.
Problem is while hiting the Bigip box more than 200 wideips statistics the box getting down and throwing the exception as follows:
1)
AxisFault
faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException
faultSubcode:
faultString: java.net.SocketException: Connection reset
faultActor:
faultNode:
faultDetail:
{http://xml.apache.org/axis/}stackTrace:java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:168)
at com.sun.net.ssl.internal.ssl.InputRecord.readFully(InputRecord.java:293)
at com.sun.net.ssl.internal.ssl.InputRecord.read(InputRecord.java:331)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:789)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1112)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1139)
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1123)
at org.apache.axis.components.net.JSSESocketFactory.create(JSSESocketFactory.java:186)
at org.apache.axis.transport.http.HTTPSender.getSocket(HTTPSender.java:191)
at org.apache.axis.transport.http.HTTPSender.writeToSocket(HTTPSender.java:404)
at org.apache.axis.transport.http.HTTPSender.invoke(HTTPSender.java:138)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.client.AxisClient.invoke(AxisClient.java:165)
at org.apache.axis.client.Call.invokeEngine(Call.java:2784)
at org.apache.axis.client.Call.invoke(Call.java:2767)
at org.apache.axis.client.Call.invoke(Call.java:2443)
at org.apache.axis.client.Call.invoke(Call.java:2366)
at org.apache.axis.client.Call.invoke(Call.java:1812)
at iControl.GlobalLBWideIPBindingStub.get_statistics(GlobalLBWideIPBindingStub.java:1243)
at statistics.WideipStatistics.getwideipStatus(WideipStatistics.java:116)
at statistics.WideipStatistics$1.run(WideipStatistics.java:93)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
{http://xml.apache.org/axis/}hostname:mobile5
at org.apache.axis.AxisFault.makeFault(AxisFault.java:101)
at org.apache.axis.transport.http.HTTPSender.invoke(HTTPSender.java:154)
Caused by: java.net.SocketException: Connection reset
... 15 more
2)or some times following exception will occur:
{http://xml.apache.org/axis/}stackTrace:javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake
if the connections are less than 200 then its giving perfect result.
so please can you give me the suggestion how to solve this problem
Thanks in advance
  • Rajesh, this looks like a bug in iControl - raise a support issue with F5 support.
