"the python bigsuds module is required"
I am unable to solve this one. I am getting started with Ansible and F5's Ansible modules. When I try to create a pool or get facts about my BigIP, I get the following error. "the python bigsuds module is required". This happens across all of my BigIP laboratory environments including an AWS one.
I am new to Python, but I believe I have it setup correctly. I am using virtualenv according to the directions, and have bigsuds, suds, and f5-sdk all installed in my virtualenv. I am verifying this with a pip list.
Yet, my ansible installation refuses to find bigsuds and when I try to do the facts suds as well.
Does the ansible site.yml have to be under the virtualenv root (ansible2) to find bigsuds? I feel like I am missing something. Any help, anyone could lend would be greatly appreciated.
-Tom
- Thomas_A__McGonHistoric F5 Account
Figured it out, I had to set PYTHONPATH export PYTHONPATH=/usr/local/lib/python2.7/site-packages
Super psyched to get started with Ansible and F5...
Ran into another issue. It appears that after Python 2.7.9 python is now checking to see if a self signed cert is in use. The error is pretty ugly. It is:
"msg": "received exception: \ntraceback: Traceback (most recent call last):\n File \"/var/folders/_r/ht1v5f8n31s9cm78mjn9scpw0000gn/T/ansible_JxdNYg/ansible_module_bigip_facts.py\", line 1659, in main\n saved_active_folder = ()\n File \"/var/folders/_r/ht1v5f8n31s9cm78mjn9scpw0000gn/T/ansible_JxdNYg/ansible_module_bigip_facts.py\", line 143, in get_active_folder\n return self.api.System.Session.get_active_folder()\n File \"/usr/local/lib/python2.7/site-packages/bigsuds.py\", line 360, in __getattr__\n client = self._client_creator('%s.%s' % (self._name, attr))\n File \"/usr/local/lib/python2.7/site-packages/bigsuds.py\", line 170, in _create_client\n raise ConnectionError(str(e))\nConnectionError: \n"
To fix this issue, all you need to do is specify validate_certs: false to the end of your bigip Ansible task. i.e.
tasks: - name: Get all of the facts from my BIG-IP bigip_facts: server: "{{ inventory_hostname }}" user: "admin" password: "admin" include: "system_info" validate_certs: "false"
- JRahm
Admin
yeah, not fun. I use (for interactive development and shorter scripts):
import requests requests.packages.urllib3.disable_warnings()
