LEON_LI_38034's avatar
LEON_LI_38034
Sep 12, 2014
The problem about iCall's tmsh script.
The following three parts what effect is there in the iCall 's tmsh Script? The default value is "none".
1、app-service none
2、description none
3、events none
I did not find the detail in the devcentral website.
The following is the default script format.:
create script test {
app-service none
definition {
description none
events none
Thanks LEE
  • In lieu of perhaps a better answer, I believe that the app-service tag is an iApp thing that allows you to define an object as part of an application service inside an iApp object. The description tag is a holder for plain text description information. And I have no idea hat the events tag is, but then I've never seen an iCall script use this tag.
  • John_Alam_45640's avatar
    John_Alam_45640
    Historic F5 Account
    The iCall script as a configuration object, could have been created by an iApp Application-service. In that case, the app-service field would reflect the service that did so.
    The description is a Text field for the user to document the purpose of the iCall script, or anything else.
    The iCall script "definition" section can generate Events, in that case it will publish the Event details in the "events" section, here is an example:
    sys icall script get_sharepoint_score_new_and_improved {
        app-service none
        definition {
            package require http
        if {[catch {tmsh::generate sys icall event SharePoint_SCORE context \{ \{ name node_addr value $nodeaddr \} \{ name score value $spscore \} \}} err]} {
                    puts "generate iCall event FAIL $url"
                    http::cleanup $token
        description none
        events {
            SharePoint_SCORE {
                app-service none
                contexts {
                    node_addr {
                        app-service none
                    score {
                        app-service none
    The only required section for an iCall script is the definition section. The events, app-service and description can be left as "none".
    Here is an example of a script which sends an email upon a failover Event. Note the FAILOVER event is system defined and it does not require special definition.
    sys icall script email-on-failover  {
        definition {
            set old_status standby
            while { 1 } {
                EVENT::get_next
                set new_status $EVENT::context(/Common/traffic-group-1)
                 detect if we just went standby
                if { $new_status eq "standby" && $old_status ne "standby" } {
                    puts "failover detected - i am standby now!"
                    set date [clock format [clock seconds] -format "%Y%m%d%H%M%S"]
                    set settings [tmsh::get_config sys global-settings]
                    set host [tmsh::get_field_value [lindex $settings 0] hostname]
                    puts "generating email for $host-$date"
                    set args "echo \"Failover notification\" | mail -s \"$host is now Standby.  $date\" [email protected]“
                    if { [catch {  exec  /bin/bash -c $args  }] } {
                        puts "\nCould not send email, try again."
                 save the state
                set old_status $new_status
        description none
        events none
    And the following perpetual handler to run it upon a Failover Event:
    sys icall handler perpetual handle-failover {
        subscriptions {
            failover {
                event-name FAILOVER_STATE
    You also need to prepare the bash mail client.
    HTH
