Lucas_de_Aguil1's avatar
Lucas_de_Aguil1
7 years ago
TCP::respond works with both ASCII and HEXADECIMAL bases?
Hey guys,
I need to send back a message with the command TCP::respond.
The message starts with its size in HEXADECIMAL (like 0065) and the rest of the message is in ASCII.
That works? Or I have to use another command to do that?
  • Like the example below, where the 0065 is hexadecimal and the rest is ascii:
    when CLIENT_DATA {
        set message "0065thisisamessage"
        TCP::respond $message
  • Maybe this,
    when CLIENT_DATA {
        TCP::payload replace 0 [TCP::payload length] ""
    This is technically how you would respond to a client with TCP data. Maybe the bigger question is if the client accepts it this way.
  • Do you mean concatenate different format type?
    Try
    set message [binary format H4a* 0065 "thisisamessage" ]
    • H4 means second parameter is 4 hex
    • a* means third parameter is binary with not fixed length
    ASCII encoding is binary... so use a* to include ascii string
