TCP::close, connection clean up
In the iRule I am writing, I have a condition where if too many errors are seen from the client, I want to error back to them and close out of TCP connection using the TCP::close command. Currently, I only issue this command on the clientside, particularly in the CLIENT_DATA section on my iRule.
My question is, does the TCP::close command issued on the client, also clean up the connection on the server side as well? Sorry if this is a repeated question, but I searched a number of places on devcentral and could find an answer. Most of the iRule I reference only show it TCP::close action issued on one side and not both. Because our LTM will be in a highly utilized environment, I want to make sure my coding is a clean/efficient as possible.
Thanks for the help!
- nitass
Employee
in my lab, bigip sends FIN on both sides (client and server side). it is shown at line (1) and (2) in tcpdump when using TCP::close command below.[root@ve10:Active] config b virtual bar list virtual bar { snat automap pool foo destination 172.28.19.252:23 ip protocol 6 rules myrule } [root@ve10:Active] config b pool foo list pool foo { members 200.200.200.101:23 {} } [root@ve10:Active] config b self 200.200.200.10 list self 200.200.200.10 { netmask 255.255.255.0 vlan internal allow default } [root@ve10:Active] config b rule myrule list rule myrule { when CLIENT_ACCEPTED { TCP::collect 1 0 } when CLIENT_DATA { if { [TCP::payload] eq "z" } { TCP::close return } TCP::release TCP::collect } } tcpdump when exiting normally (exit command) 14:56:09.431776 IP 200.200.200.101.23 > 200.200.200.10.60462: FP 216:230(14) ack 81 win 46 14:56:09.431792 IP 200.200.200.10.60462 > 200.200.200.101.23: . ack 231 win 4609 14:56:09.431798 IP 172.28.19.252.23 > 192.168.206.33.60462: FP 216:230(14) ack 81 win 3860 14:56:09.433824 IP 192.168.206.33.60462 > 172.28.19.252.23: . ack 231 win 259 14:56:09.434854 IP 192.168.206.33.60462 > 172.28.19.252.23: F 81:81(0) ack 231 win 259 14:56:09.434868 IP 172.28.19.252.23 > 192.168.206.33.60462: . ack 82 win 3860 14:56:09.434872 IP 200.200.200.10.60462 > 200.200.200.101.23: F 81:81(0) ack 231 win 4609 14:56:09.435837 IP 200.200.200.101.23 > 200.200.200.10.60462: . ack 82 win 46 tcpdump when using TCP::close (press z) (1) 14:56:49.971766 IP 200.200.200.10.60464 > 200.200.200.101.23: F 75:75(0) ack 210 win 4589 (2) 14:56:49.971773 IP 172.28.19.252.23 > 192.168.206.33.60464: F 210:210(0) ack 76 win 3855 14:56:49.972820 IP 200.200.200.101.23 > 200.200.200.10.60464: F 210:210(0) ack 76 win 46 14:56:49.972838 IP 200.200.200.10.60464 > 200.200.200.101.23: . ack 211 win 4589 14:56:49.973879 IP 192.168.206.33.60464 > 172.28.19.252.23: . ack 211 win 260 14:56:49.973889 IP 192.168.206.33.60464 > 172.28.19.252.23: F 76:76(0) ack 211 win 260 14:56:49.973899 IP 172.28.19.252.23 > 192.168.206.33.60464: . ack 77 win 3855
