TCP monitor with sending a byte sequence
One of our customers is using a TCP/IP based application and instead of using the default TCP monitor, they will check their application with sending a specific byte sequence after the TCP connect. If the server answers then with the same byte sequence it can be treated as healthy.
From a C sample code the byte sequence is defined like this:
private static readonly byte[] _ByteSequence = new byte[] { 62, 122, 33, 83, 70, 46, 14, 74, 164, 167, 81, 253, 54, 254, 113, 78, 128, 0, 101, 99, 104, 111, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 4, 0, 0, 0, 112, 105, 110, 103, 255, 255, 255, 255 };
But currently I have totally no clue how I can handle this with (I guess) and external monitor.
Did someone realized something similar or has an idea how the script should look like?
Thank you!
Ciao Stefan :)
