johnbernardcheu's avatar
Oct 20, 2017
TCP Max Segment Size(MSS) and Path MTU Discovery question
Hi there,does PATH MTU take precedence over the MSS MTU? Thanks!
  • It Depends, if MSS MTU is smaller, it will cause chatty communication
    If Oversized MSS, it will generate can't fragment ICMP
    F5 LTM will detect client path MTU with following command
    tmsh show net cmetrics
    • johnbernardcheu's avatar
      johnbernardcheu
      Icon for Cirrus rankCirrus
      So if MSS is configured for 536 and path MTU is 1500, what is the max MSS...is it 536 or 1460?
