Michael_C_16907's avatar
Michael_C_16907
Feb 01, 2010
TCL error in running iRule
I see Failures in my iRule:
TCL error: Rule Rules CLIENT_ACCEPTED - invalid command name TCP::port8 while executing TCP::port[TCP::local_port] equals 25
Here is my code.
when CLIENT_ACCEPTED {
if{([TCP::port[TCP::local_port] equals 25]) or ([TCP::port[TCP::local_port] equals 110]) or ([TCP::port[TCP::local_port] equals 1723]) or ([TCP::port[TCP::local_port] equals 1701])}{
use pool HGC_Persistent_GW
}elseif{[IP::addr [IP::local_addr] equals 118.143.13.0/24]}{
use pool HGC_Pool
}elseif{[IP::addr [IP::local_addr] equals 203.186.55.0/24]}{
use pool HKBN_Pool
Actually should it be just (TCP::local_port equals 110) insteed?
  • hoolio's avatar
    hoolio
    You're correct; you can just use TCP::local_port. There is no 'TCP::port' command. There is an IP::addr command to compare IP addresses. You could also replace the if chain with a switch statement:
         Check the client's requested port (the local port)
        switch [TCP::local_port] {
           "25" -
           "110" -
           "1723" -
           "1701" {
           default {
              if {[IP::addr [IP::local_addr] equals 118.143.13.0/24]}{
                 pool HGC_Pool
              } elseif {[IP::addr [IP::local_addr] equals 203.186.55.0/24]}{
                 pool HKBN_Pool
    Aaron
