take a UCS on system1 and restore it on system2
Hi;
When you take a UCS on system1 with LTM and DNS modules and their specific configuration and then restore it on system 2 which has a license only for LTM, how would that work? would the configuration restore correctly
Kindly Wasfi
Config load would fail. You can address this issue by loading System2 configuration from an UCS which does not have DNS module provisioned. Go to System -> Resource Provisioning, and untick DNS. After a reboot, you can create an UCS on System1 which is exempt of any DNS/GTM config. This should load successfully on System2 which is the LTM-only box.
If you're familiar with the UCS archive, you can also get your UCS prepared without any downtime. Since UCS is equal to a regular unix tarball, it's possible to extract the files from it, have them modified, and re-bundled into a new UCS tarball.
Regards,
- Hannes_Rapp
Regards,
- Wasfi_182818
Altostratus
Thank you Hannes
- Hannes_Rapp_162
Nacreous
Regards,
- Wasfi_182818
Altostratus
Thank you Hannes
