Girish_HS_32793
Mar 28, 2009System Uptime reset
Hi Team,
I recently got a uptime alert on one of my standby LTM BIG-IP Version 9.1.2 97.0 HF7.
I could not find any error logs on the /var/log/ltm.
I did not see any specific errors of the box getting a reboot.
[[email protected]:Standby] woadmin uptime
10:36:31 up 28 min, 1 user, load average: 1.00, 1.00, 1.00
[[email protected]:Standby] woadmin b failover show
FAILOVER standby for 465 days 16:33:18
Is this a bug? Did the uptime auto reset by itself ? what am I missing here ?
Can someone please help me find a solution.
Thanks in Advance.
Girish
- The_Bhattman
as odd as the read out is, I think the uptime is pretty accurate that it did reboot. However, did you check the sccp to see if there was any errors there.
thanks,
CB - hwidjaja_37598
Altostratus
Could it be due to your system has been up for more than 497 days (approximately 16 months)?
Check SOL7036: Click here
you can try to see the real system boot from:
"last reboot -1" or "who -b" - The_Bhattman
Looking at Girish's output it has been up for less then 497 days.
CB - Girish_HS_32793
[[email protected]:Standby] woadmin last reboot -1
wtmp begins Thu Mar 5 04:06:21 2009
[root@eng-engint-lbd2:Standby] wo501684293
I don't see any message that says reboot. What does "wtmp begins Mar 5th" Mean ????
Regards,
Girish HS - Girish_HS_32793
. - Girish_HS_32793
