syntax error in iRule using data group
in LTM V10.2, I am trying to match against a bunch of IPs included in a datagroup and am getting an error. The datagroup config looks good (see below) and when I remove the $::safeiiplist and insert a single IP, it works.
when HTTP_REQUEST { set username [HTTP::cookie username] log local0. "URI is [string tolower [HTTP::uri]]. Username is $username." if {($username contains "\@jones") || ($username contains "\@smith") } { log local0. "Matched username! Username is $username." if { [IP::addr [IP::client_addr] equals $::safeiiplist] } { log local0. "Matched client address: [IP::client_addr]" switch -glob [HTTP::uri] {
ERROR: bad IP network address format invoked from within "IP::addr [IP::client_addr] equals $::safeiiplist"
Datagroup config: class safeiiplist { host 207.140.60.67 }
- Cory_50405
Noctilucent
Instead of this:
if { [IP::addr [IP::client_addr] equals $::safeiiplist] } {Use this:
if { [class match [IP::client_addr] equals safeiiplist] } { - TMcGov_92811
Cory, thanks alot this logic works. Maybe its just my OS version, but this is what works for me:
if { [matchclass [IP::client_addr] equals $::safeiiplist] } {
- Cory_50405
Noctilucent
Yes, 'matchclass' is v10. 'class match' is v11. Apologies for not catching that from your original post.
