Tummala_Nithi_3
Apr 12, 2019Sync issue problem - F5
Hi ,
When have F5 which is in HA. And after certificate renewal the device was in sync. Later when we had done few changes to configuration, and when tried to sync we got the below error.
"The requested profile clientssl (clientssl-insecure-compatible) was not found. Recommended action: Review the error message and determine corrective action on the device"
Can someone please provide a solution?
- Yoann_Le_Corvi1
Cumulonimbus
Hi
Did you by an chance modify the default clientssl profile :-) ? If so I would try :
- First reset the default SSL profile to its default values (and default certs)
- Redo the cluster trust
- Then create a specific profile for your own use.PS : in general I would NEVER modify default profiles on BigIP
Let us know if this helps.
Yoann
