Ted_Waller_01_1's avatar
Ted_Waller_01_1
Dec 16, 2014
Switch Statement Routing to Separate VS Using 'Virtual'
Good afternoon,
I am trying to route traffic based upon a URI switch using -glob to a separate virtual server. I've read up on the 'virtual' command, and think I have the syntax right, but there's something wrong that I can't pinpoint. Wondering if anyone had any guidance as to what to try next?
iRule:
        set uri1 [string tolower [HTTP::uri]]
        switch -glob $uri1 {
                "/uriA*" -
                "/uri1/uri2/v1*" {
            log x.x.x.x local0.info "URI Var: $uri1"
            log x.x.x.x local0.info "Routing to vs for api_stage_https"
            virtual api_https
            log x.x.x.x local0.info "VS: [virtual name]"
            return
                default {
                        pool app
The logs I get when hitting this is:
Dec 16 14:07:33 LTM tmm[9290]: Rule /Common/app_rule : URI Var: /uri1/uri2/v1/uri3 Dec 16 14:07:33 LTM tmm[9290]: Rule /Common/app_rule : Routing to vs for api_stage_https Dec 16 14:07:33 LTM tmm[9290]: Rule /Common/app_rule : VS: /Common/app_https
I also have log statements in the api_https virtual server but they never get triggered. If I manually go to the api_https virtual server with a direct link, it works fine. But within this logic it doesn't seem to work. Thoughts?
Also, we're running BIG-IP 11.4.0 Build 2425.0 Hotfix HF4 currently.
Ted
  • The logic seems fine to me. Some suggestions:
    1. Can you check by removing the "return" in the above logic ?
    2. The api_https virtual server, can you test it by enabling it on all Vlans ?
    Best
  • The return was only added after initial attempts that failed (exact same behavior) after finding a suggestion on a previous response here. I've also tried dropping down to the http version of the VS along with https. The issue seems to be it's just not assigning the traffic to the new VS despite the command being there.
    Here's the first part of the iRule attached to the api_https (and api_http for that matter) virtual server. I only included the first part to show that immediately upon hitting the Vs, it should hit this iRule resulting in the log statement firing. I never receive that statement. Also, I can hit the api_https (or api_http) directly, so the IP restriction you see has been validated.
        if { [IP::addr [IP::client_addr]/24 equals IP1]
            or [IP::addr [IP::client_addr]/23 equals IP2]} {
                log 10.10.0.9 local0.info "Host: [HTTP::host] -- URI: [HTTP::uri] "
    • Amit_Karnik_269's avatar
      Amit_Karnik_269
      Just to rule it out do enable the api_https on all VLANs. When you hit it from the outside and when the traffic is shuffled from 1 virtual to another, there is a a subtle difference. You could also add a log statement in your iRule on api_https in the CLIENT_ACCEPTED event just to see if the connection is setup
  • Hmm ok I do see the connection set up. Perhaps it's just the secondary iRule that is broken. My .NET code is getting a "Underlying connection is closed." Let me dig into this more, perhaps I missed something. Though the fact the secondary iRule/VS works on it's own is odd.
    It's also open to all VLANs.
  • Couple of things. Since you're running iRules on these, I'm assuming that you have an SSL-Client side profile on both the API vip as well as the front end. That being the case, sending to the HTTPS virtual could very well be your problem since you've already decrypted the traffic on the first VIP.
    We do this handoff using the virtual comand all the time without issue. Other than the previosly mentioned "return", there's nothing wrong with what you're doing... as long as you're not having to deal with to SSL-CS profiles.
  • Thanks. I'll go back to HTTP and try to get it working there, and then try to figure out if I can do the SSL part. If not, I may have to adjust the strategy here.
  • Just to clarify what's going on with the "virtual" command. The traffic never actually leaves the box when using this method. No reason to worry about it being unencrypted in transit. If you run a tcpdump, you can watch the transition from the first vip to the second, never exposed outside of the hardware.
    tcpdump -s0 -ni0.0 -w /var/tmp/ host or host
    https://devcentral.f5.com/wiki/iRules.virtual.ashx
    Note: In version 9.4.0 and higher, 'virtual ' can be used to route the connection to another virtual server, without leaving the BIG-IP. This functionality did not exist in previous versions. In order to make this functionality work, one must precede the virtual command with an LB::reselect command if a pool member has already been selected.
  • Yeah I do see it hit the second VIP and associated iRule. The issue is, I see it trip the CLIENT_ACCEPTED block but not the HTTP_REQUEST block. By trip, I mean I can get a log message out to my syslog server. That's where I'm stuck, is why it's not getting into the HTTP_REQUEST part.
    • cdougall_14195's avatar
      cdougall_14195
      Icon for Cirrus rankCirrus
      Do you get the same results when the second VIP does not have a client SSL profile?
      cdougall_14195
  • Correct. We have to VIPs defined, one with SSL, one without. If I target the one without, it still exhibits the same behavior. I have to dig into more why it's opening the connection but then dying before it enters the http_request. But I haven't had time yet to try and see why that's the case.
  • if the back end virtual server is https, serverssl profile is needed on the front end virtual server. it has been configured, hasn't it?
