tidenz_92110's avatar
tidenz_92110
Oct 07, 2009
switch command questions
Hi Guys,
I am trying to mimic a rule we currently have configured on our web servers.
RewriteCond %{REQUEST_URI} ^/view/.*\.do.*
RewriteCond %{REQUEST_URI} !^/view/secure/.*\.do.*
RewriteCond %{REQUEST_URI} !^/view/en_AU/secure/.*\.do.*
RewriteRule ^/(.*) http://abc.com.au/$1 [R,L]
switch -glob [HTTP::uri] {
"/view/*.do*" {
HTTP::redirect "http://abc.com.au[HTTP::uri]"
"/view/secure/*.do.*" {}
"/view/en_AU/secure/*.do.*" {}
as far as order of operation goes the first entry matches the 2 below so should i put the most specific first and the least specific last?
If a match is made do the rest of the arguments get parsed?
also it is possible to use the not equals operator when using switch?
  • hoolio's avatar
    hoolio
    Only one switch case will be matched. You can add a default case if you want to catch any non-matches:
     switch $some_string {
        "case 1" {
            case 1 action here
        "case 2" {
            case 2 action here
        default {
            default action here
    If /view/*.do*" will match more generically, you should put it after the other cases. Not equals like logic isn't possible, but again, you can use default to as a catch-all.
    You can add logging to the switch cases to verify what's happening.
    Aaron
  • Thanks hoolio i figured it would work the same as use case statements but i wanted to be sure.
