SWG iRule per-packet policy
Hello,
I'm working on SWG and would like to configure/assign different per-request policy as per client request. - If request is from IP address A or IP address B then use per-request policy A or Per-request policy B, we need to configure dynamic per-request policy.
Is it possible to achieve this using iRule in APM access policy?
Thanks, Sachin
You can do it with an iRule. It is not possible use iRules to switch PRPs, but you can create source Ip-based branches within a single per-request policy. In the Per-Request Policy, you can create an Empty action, and assign a branch to it with the following check:
expr { [IP::addr [mcget {session.user.clientip}] equals "10.0.0.0/8"] }
That branch will hit if the IP address comes from 10.0.0.0/8 subnet. There is an IP Subnet Match action the main access policy that is unfortunately not available in Per request access policy - so you need to create it manually.
- sachin_80710
Thanks Michael, good I don't need irule. But as per SWG 11.6 implementation guide page 53 under Session variables for use in a per-requestpolicy. There they mentioned only 4 session that can be used in PRP. - This should work - try it.
- Michael_Koyfman
Cirrocumulus
- sachin_80710
Thanks Michael, good I don't need irule. But as per SWG 11.6 implementation guide page 53 under Session variables for use in a per-requestpolicy. There they mentioned only 4 session that can be used in PRP. - Michael_Koyfman
Cirrocumulus
- F5_Jeff
Cirrus
Hi all,
From what I've read, the IP subnet match is now included as VPE agent and no need to manually configure as a rule in version 15. It is under the endpoint security (server-side) per-request policy items
