Suggestions and precautions for upgrading Virtual Load Balancer
Hi All,
I am planning to upgrade our Virtual Load Balancer from version 11.5.1 to 11.6.1 and also upgrading the hotfix.
Please suggest upgrading steps, precautions and at what steps do i need to take downtime.
Thanks & Regards Ashish Solanki
- Vijay_E
Cirrus
11.5 to 11.6 is a relatively minor code upgrade and you shouldn't see any serious issues in terms of configuration incompatibility. However, it is good to remove any unused configuration elements like iRules or profiles that are not being utilized.
Save configuration & license on the box and off the box.
- Alex_104543
Cirrus
Perhaps you can take a look at the manual on software upgrade:
Also, you may need to re-activate the license prior to version upgrade:
