khumfleet
Feb 21, 2012Stuck...Simple iRule? Not sure...req for Help
We are trying to use our LTM to route medical imaging (also known as DICOM) traffic to from our clients to one of two medical imaging archives (also known as a PACS) at our headquarters.
A...
nitass
Employee
Feb 05, 2014what about something like this?
config
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.24.10:80
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
tcp { }
rules {
myrule
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 2
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
members {
200.200.200.101:80 {
address 200.200.200.101
200.200.200.111:80 {
address 200.200.200.111
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule myrule
ltm rule myrule {
when CLIENT_DATA {
if { [TCP::payload] contains [IP::local_addr] } {
set newpayload [string map "[IP::local_addr] [LB::server addr]" [TCP::payload]]
TCP::payload replace 0 [TCP::payload length] ""
TCP::payload replace 0 0 $newpayload
TCP::release
TCP::collect
when LB_SELECTED {
TCP::collect
trace
[root@ve11a:Active:In Sync] config ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.24.1(36926) <-> 172.28.24.10(80)
1391605062.9816 (0.0018) C>S
GET / HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Host: 172.28.24.10
Accept: */*
New TCP connection 2: 200.200.200.14(36926) <-> 200.200.200.101(80)
1391605062.9837 (0.0015) C>S
GET / HTTP/1.1
Host: 200.200.200.101
Accept: */*
