Joe_Pipitone's avatar
Joe_Pipitone
Jan 26, 2011
Stripping part of URI and integrating with iRule
I have to perform the following:
http://www.oursite.org/directory1/directory2/somepage.aspx needs to rewrite to http://oursite.org/somepage.aspx - essentially just stripping out directory1 and directory2.
I also need to be able to strip the www as well.
I've tried the following iRule that I found as hoolio's example, however it seems to end up getting stuck in a redirect loop.
I also do not want to string map, I need to actually rewrite the URI.
Can anyone tell me what I might be doing wrong? The bigip log shows:
Original URI: /directory1/directory2/somepage.aspx
Current URI: /somepage.aspx
Which seems to be correct, however redirect loop still occurs.
log local0. "[IP::client_addr]:[TCP::client_port]: Original URI: [HTTP::uri]"
switch -glob [HTTP::path] {
"/directory1/directory2*" {
HTTP::uri [string map {"/directory1/directory2/" "/"} [HTTP::uri]]
HTTP::redirect "http://oursite.org[HTTP::uri]"
default {
HTTP::redirect "http://oursite.org"
when HTTP_REQUEST priority 501 {
log local0. "[IP::client_addr]:[TCP::client_port]: Current URI: [HTTP::uri]"
I then need to integrate this functionality into the bottom of this iRule, I've stripped most of it as it is very long. The following is at the very end of a large switch statement, and needs to be preserved
default {
if {[HTTP::uri] starts_with "/admin" } {
HTTP::redirect "http://legacy.oursite.org[HTTP::uri]"
} elseif {[string tolower [HTTP::host]] eq "www.oursite.org"}{
Much thanks for any help!
