Dan_Bowman's avatar
Mar 07, 2019
Solved
ASM stripping double quotes from cookie values post v14?
Noticed one of our apps stopped working after moving from v13.1 > v14.1.0.2
Investigation suggests ASM is stripping quotes from JSESSIONID cookies and preventing sessions from being initiated - has anyone encountered this before?
For example:
Mar  7 15:00:58  : JSESSIONID="uniquevalue.servername:server-one";
Mar  7 15:00:58  : JSESSIONID=uniquevalue.servername:server-one;
Backend servers interpret this as two separate values and session can't be established.
Removing ASM policy from VS removes the issue, and quotes are maintained on http_request_release
  • To close this off - the issue was corrected in v14.1.2.1
    769997-1 : ASM removes double quotation characters on cookies
    Component: Application Security Manager
    Symptoms:
    ASM removes the double quotation characters on the cookie.
    Conditions:
    Cookie sent that contains double quotation marks.
    Impact:
    The server returns error as the cookie is changed by ASM.
    Workaround:
    Set asm.strip_asm_cookies to false using the following command:
    tmsh modify sys db asm.strip_asm_cookies value false
    Fix:
    ASM no longer removes the double quotation characters on the cookie.
    https://techdocs.f5.com/kb/en-us/products/big-ip_ltm/releasenotes/related/relnote-supplement-bigip-14-1-2-1.html#A769997-1
  • v14 is relatively new and this might be a genuine issue in ASM v 14.x - I suggest opening a Support Case with F5 to investigate
  • We are experiencing exactly the same: ASM seems to be stripping double quotes to cookies in our applications.
    The behaviour started after updating to v14.0.
    Edit: the problem is the same, not the opposite.
  • Raised a SR with F5 Support and they advised the following:
    A feature to not pass ASM cookies was introduced in this version. Engineering Services team indicated to disable the feature:
    Symptoms:
    Conditions:
    Impact:
    Workaround:
    Fix:
