Kyle_S's avatar
Kyle_S
Apr 20, 2015
String tolower within a switch -glob
We are routing traffic to various Pools by their URI. Our developers are implementing a change to the name of the of the incoming URI and need it to point to the existing Virtual Directory on the server. It works using a string map but it has to be the correct case. I have a string tolower with the switch -glob but it doesn't carry over when it matches on the string map. Is there a way to have both of the functions string tolower?
    switch -glob [string tolower [HTTP::uri]] {
    "/vd/service/*" {
                       HTTP::uri [string map {"/VD/service/" "/change1/"} [HTTP::uri]]
                                 pool Pool_service}
    "/vd/forms/*" {
                       HTTP::uri [string map {"/VD/Forms/" "/change2/"} [HTTP::uri]]
                                 pool Pool_forms}
    "/vd/orders/*" {
                       HTTP::uri [string map {"/VD/Orders/" "/change3/"} [HTTP::uri]]
                                 pool Pool_orders}
    "/vd/contact/*" {
                       HTTP::uri [string map {"/VD/Contact/" "/change4/"} [HTTP::uri]]
                                 pool Pool_contact}
          default {
                discard
  • Kyle_S's avatar
    Kyle_S
    Thanks nitass, that did it. This is what I have in place, in case anyone else needs it as a reference:
        "/vd/service/*" {
                           HTTP::uri [string map -nocase {"/VD/service/" "/change1/"} [HTTP::uri]]
                                     pool Pool_service}
        "/vd/forms/*" {
                           HTTP::uri [string map -nocase {"/VD/Forms/" "/change2/"} [HTTP::uri]]
                                     pool Pool_forms}
        "/vd/orders/*" {
                           HTTP::uri [string map -nocase {"/VD/Orders/" "/change3/"} [HTTP::uri]]
                                     pool Pool_orders}
        "/vd/contact/*" {
                           HTTP::uri [string map -nocase {"/VD/Contact/" "/change4/"} [HTTP::uri]]
                                     pool Pool_contact}
              default {
                    discard
  • use "string tolower" is not match string case
    ex. when HTTP_REQUEST { if { [active_members [LB::server pool]] < 1} { switch -glob [string tolower [HTTP::uri]] { "/" { HTTP::respond 200 content [ifile get cproxy_index.html] "Content-Type" "text/html" log local0. "URI: [HTTP::uri]" } "/503/img_logo.gif" { HTTP::respond 200 content [ifile get img_logo.gif] "Content-Type" "image/jpeg" log local0. "URI: [HTTP::uri]" } "/503/logo_nomuraUN170-16.gif" { HTTP::respond 200 content [ifile get logo_nomuraUN170-16.gif] "Content-Type" "image/jpeg" log local0. "URI1: [HTTP::uri]" } default { HTTP::respond 200 content [ifile get logo_nomuraUN170-16.gif] "Content-Type" "image/jpeg" log local0. "URI2: [HTTP::uri]" } } } } this case when uri="/503/logo_nomuraUN170-16.gif" is not match , default case "log local0. "URI2: [HTTP::uri]" output
    whenever change switch -glob [string tolower [HTTP::uri]] ==>switch -glob [HTTP::uri]
    then when uri="/503/logo_nomuraUN170-16.gif" is match "/503/logo_nomuraUN170-16.gif" and log local0. "URI: [HTTP::uri]" output
    string tolower is not use.
