AngryCat_52750
Nov 16, 2012string tolower help
I have an irule working as such -
set host_used [HTTP::host]
set uri_used [HTTP::uri]
if { [HTTP::uri] starts_with "/Common/HomeAddress/ABCdef" } {
log local0. "[IP::client_addr] sent request $host_used $uri_used"
When i try using the "string tolower" it errors out.. what am i doing wrong?
if { [string tolower [HTTP::uri]] starts_with "/Common/HomeAddress/ABCdef" } {
- hoolio
You'll want to put the URI you're checking into lowercase as well to get a match:
if { [string tolower [HTTP::uri]] starts_with "/common/homeaddress/abcdef" } {
Aaron - AngryCat_52750
DUH!!! thanks Aaron.
