MB_58262's avatar
MB_58262
Oct 10, 2012
string tolower and case insensitivity
We wanted to redirect to a particular request when the radius AVP such as User-Name ends with test.com. I implemented irule like the one below. From my understanding, it should be for case insensitive. so, when client request comes in with Test.com or TEST.COM or tEst.com, etc ...work, should still go to test_pool1
rule test_irule {
when CLIENT_DATA {
if { [ string tolower [RADIUS::avp User-Name] ] ends_with "test.com" } {
pool test_pool1
pool test_pool2
However, I noticed that when for example clien request has Test.com (e.g., capital T), it would go to test_pool2. The goal is to ensure that any request regardless of its case (upper or lower letter) containing a string such as "test.com" to always go to test_pool1, anything else would go to test_pool2
Any feedback would be really appreciated.
Thanks.
  • Just out of curiosity, what's the output if you throw in the following log line:
    when CLIENT_DATA {
         log local0. "User-Name = [string tolower [RADIUS::avp User-Name]]"
              pool test_pool1
              pool test_pool2
  • it looks fine to me.
    [root@ve10:Active] config  b virtual bar list
    virtual bar {
       snat automap
       destination 172.28.19.79:1812
       ip protocol 17
       rules myrule
       profiles {
          myudp {}
          radiusLB {}
    [root@ve10:Active] config  b profile myudp list
    profile udp myudp {
       defaults from udp
       datagram lb enable
    [root@ve10:Active] config  b pool test_pool1 list
    pool test_pool1 {
       members 200.200.200.101:1812 {}
    [root@ve10:Active] config  b pool test_pool2 list
    pool test_pool2 {
       members 200.200.200.111:1812 {}
    [root@ve10:Active] config  b rule myrule list
    rule myrule {
       when CLIENT_DATA {
       log local0. "[RADIUS::avp User-Name]"
       if {[string tolower [RADIUS::avp User-Name]] ends_with "test.com"} {
          pool test_pool1
          pool test_pool2
    when SERVER_CONNECTED {
       log local0. "[LB::server pool]"
       log local0. "[IP::remote_addr]:[UDP::remote_port]"
    [root@ve10:Active] config  tail -f /var/log/ltm
    Oct 11 11:17:20 local/tmm info tmm[7926]: Rule myrule : [email protected]
    Oct 11 11:17:20 local/tmm info tmm[7926]: Rule myrule : test_pool1
    Oct 11 11:17:20 local/tmm info tmm[7926]: Rule myrule : 200.200.200.101:1812
    Oct 11 11:17:27 local/tmm info tmm[7926]: Rule myrule : [email protected]
    Oct 11 11:17:27 local/tmm info tmm[7926]: Rule myrule : test_pool2
    Oct 11 11:17:27 local/tmm info tmm[7926]: Rule myrule : 200.200.200.111:1812
  • just in case if you have not yet seen this.
    sol13861: Certain UDP-based iRule commands may cause TMM to crash
    https://support.f5.com/kb/en-us/solutions/public/13000/800/sol13861.html?sr=24467406
  • Thank you for the confirmation! - I am just curious, may I ask what tool have you used to generate the radius request?
  • may I ask what tool have you used to generate the radius request?of course.
    NTRadPing 1.5 RADIUS Test Utility
    http://www.novell.com/coolsolutions/tools/14377.html
