Humair_167681's avatar
Humair_167681
Apr 14, 2015
String map help
Hi all,
Could you please explain the difference between the two commands below?
HTTP::uri [string map "/$customer/ /" [HTTP::uri]]
HTTP::uri [string map {"/$customer/" "/"} [HTTP::uri]]
Thanks.
  • I believe they are functionally equivalent. But, the second command is expressly setting the correct type for the mapping parameter. Most likely is that TCL is seeing you are passing in a string in the first command and trying to coerce it to an list of search/replace strings which that parameter is supposed to represent. Since you have a space in that string, it's convering it to the equivalent of 2.
    In an example with the TCL interpreter (tclsh), here's something similar:
    % set s 123456
    123456
    % string map {1 a} $s
    a23456
    % string map "1 a" $s
    a23456
    -Joe
  • Thanks Joe,
    Can you please elaborate "the second command is expressly setting the correct type for the mapping parameter"?
    Sorry - I don't seem to understand what you mean there.
    Regards,
    Humair
